my first rally - vomit, cracked sump & 2nd place
reggiegasket
Post Fri Nov 24, 2006 7:35 pm
I just did my first rally in the 318is. Not the sort of motor sport I thought I would do, but a friend of mine has been doing it for years. He offered to navigate in a local "12 car".
I thought, why not, as you do. I got the brake fluid and pads changed so they wouldn't go off. Changed the bulbs to 100W. I took the lip spoiler off the front and the centre caps off the wheels and that was it. We intended to put harnesses in, but they needed slight modification and, of course, we found this out too late to do anything about it...
The event was £15 quid to enter. How cheap is that? We arrived at a caravan park at 8.15pm. ALready 15 minutes late. You sign some forms and join the club (£8) and that's it. They give you a form with a set of time checks and route checks (codes on little signs to check you actually do the route) written as grid references and the direction you approach or leave. You then plot these on a map so you know the basic shape of the route. However, some instructions are given out on route, so you only know 60% of where you are going.
Then we were off. Some bits are neutral, so you don't have to push. SOme bits are timed and you have to keep up a 30 mph average - sometimes easy, sometimes hard. At each time check they record the time you arrive - mostly retired gents, wives, and rally boys not competing. The roads were lake district back roads.
The BM did really well. We discovered it brakes well, turns in well and generally feels good on those roads. The route took us about 2.5 hours and was quite complex to work out. My experienced navigator had to work hard and that resulted in 2 vomit stops. Poor guy. Never done it before, he said :o:
They throw in a couple of grassy bits and those were a dissaster. The BM has no grip on wet grass whatsoever. We got stuck once on a flat bit. I also nutted the sump on a rock - cracked sump. Fortunately a small drip, which didn't stop us - I only noticed the next day :x
The winner is the person with to most route checks - i.e. they did the full route. I think we had most of the codes. If 2 poeople have the same number of codes, they look at the times. We came second. This is really due to the navigator being good rather than me, but I keep up a decent speed. At some points I thought I was driving well and got a racing buz :cool:
No real botty clenchers :eek: but I'm sure they happen. The BMW coped with the event so well. They are just so well made. I need a sump guard and probably need to raise the ride height a bit. I'm going to do some more - I just want an excuse to set the car up winkeye
List of wants: LSD, new suspension (although MTech was OK), harnesses, faster steering.
Cheers, G
thebigone
Post Fri Nov 24, 2006 7:41 pm
sonds like a whale of a time. keep flying the flag :D
Demlotcrew
Post Fri Nov 24, 2006 7:55 pm
Sounds like really good fun!
Morat
Post Sat Nov 25, 2006 5:54 pm
Congrats!
maxfield
Post Sat Nov 25, 2006 6:10 pm
sounds good
Andyboy
Alpina Colada
Post Sun Nov 26, 2006 9:50 am
12 car plot and bash night rallies are Ace. I did a few in the late eighties with the Oxford Motor Club in a Mini 1275GT (LHK497J :-) ..) complete with a pair of Cibies on the front. Once, the local Autoglass sales rep and I did one in his new Escort 1.8 diesel company car. The Cibies were robbed from the Mini and fitted to this thing with some crafty brackets. All was going well unil he misjudged a corner and launched the 'Scort though a hedge into a field. Well we got it out, finished the rally and jet washed all the mud and shit off the car.
Not a mark on it......... :clap: :cheers:
mrLEE30
Post Sun Nov 26, 2006 10:09 am
harder than you think to average 30mph!! well done!!
cheap motorsports are getting harder and harder to come by, i even packed in racing my Rotax kart as it was costing silly money to remain competitive :cry:
FBF
Post Sun Nov 26, 2006 11:51 am
same here mrlee that and im a fat bastard.. got sick of the plug lead zapping my ass on the tillet seat bolts!! seemed to happen way to often
im so sexy justin brought me back 5 times
