M3 anti roll bar on 325?
Two_Sheds
Post Tue Nov 21, 2006 12:25 am
I noticed an M3 rear ARB for sale on ebay, just wondering if it would fit my '87 325, and if it would be a worthy upgrade. The car is a track car, primarily for drifting, its lowered 60mm all round with adjustable Avo dampers at the back, so its hardly roly poly at the moment anyway, but the ARB is so cheap I'm just wondering whether it might be worth a punt to gain a bit extra!
Post Tue Nov 21, 2006 9:25 am
I think theyre about 1mm thicker
Richy325iTouring
Post Tue Nov 21, 2006 10:48 am
aint the touring rear arb the same as the m3 as well
Theo
Post Tue Nov 21, 2006 12:03 pm
According to real oem the rear ARB on a standard m3 is 14.5mm, which is the same as a 325i sport, and only 1mm thicker than the standard 13.5mm rear ARB on a 325i.
However a 1mm increase in diameter will increase the cross sectional strength by over 15% (16.5mm squared as opposed to 14.3 mm squared)
Martinaston
Post Tue Nov 21, 2006 12:06 pm
Does it attach in the same place ? (wider track)
There is NO nucleus.
Simon
Post Tue Nov 21, 2006 12:36 pm
Yes, the M3 roll bar will straight swop, fit's in the same place as any other E30.
The front anti-roll bar mounts different on an M3, but I believe you can still use normal E30 drop links to mount to the wishbones.
Post Tue Nov 21, 2006 7:26 pm
Touring with leveling device has the same bar I belive
