Hi has any body used these coil over kits, they have staimless steel bodys and are TUV approved so sound ok to me ?
All JAMEX products are developed and manufactured to complement each other and comply with several international quality standards; e.g. the German TÃaV standard.
This is a complete coilover suspension kit to fit the vehicles listed at the bottom of this page. They are fully height adjustable and have fixed damping. They come with a two year warrenty and really are the best coilovers available on the market today. Grab a bargain while we still have stock.
Technical facts surrounding the JAMEX range
JAMEX Sportspring and Sportsline kits are well known for supreme performance with a competitive edge in every respect. With a combination of top quality materials and efficient, modern manufacturing methods, JAMEX produce the most genuine value-for-money product in the market today.
Sportspring kits consist of two-or-four-spring kits depending on the vehicle's original specification, Sportsline kits contain both springs and shock absorbers/struts as required. All JAMEX products are developed and manufactured to complement each other and comply with several international quality standards; e.g. the German TÃaV standard.
Key technical facts:
JAMEX springs are manufactured from highest grade SiCr steel.
Quality assured via German TÃaV standard compliance
JAMEX springs are forged using the more reliable 'cold-drawn' method. Some competitors use the hot-forged method of manufacture, this has an adverse effect on the springs' tensile strength: i.e. consistent tension.
Following the forging process, a temperature controlled oil based treatment is applied to the spring to ensure that the required hardness and tension is reached, thus giving full operational effectiveness throughout the springs' entire lifecycle.
The SiCr steel is initially treated with Zinc-Phosphate, and finished in an Epoxy Resin to provide effective protection of the spring.
The production process is fully automated to enable a high degree of consistency in the end product.
JAMEX shock absorbers contain both oil and gas. The gas serves to cool the oil to produce a more consistent operation.
Standard shock absorbers (for example - KONI brand) contain oil but no gas. This has a detrimental effect on quality and will reduce the lifecycle of the shock absorber significantly, even under normal driving conditions.
JAMEX Pro-Street shock absorbers are constructed to allow the amount of gas contained to be increased, to allow their performance to be improved further.
Jamex Sport shock absorbers improve damper performance by 30% compared to a standard
jamex sus?
zaust
- Zone day release
- Location: Somewhere in Hertfordshire , or press Ctrl + W
I have used jamex for many different cars and have never had a problem except there bedding in time, which is not really a bad thing. normally around 3k. they have been around for a long time and you will find them on alot of race car's, a bit stiffer than a lot of other makes but good ride. so go for it...
exup
- Boost Junkie
Cheers 4 the reply
Their spec reads well S/STEEL &TUV they seem good valve too for coil overs,
might try them
might try them
DaveD
- E30Zone Wiki Specialist
so where from
