head lamps
fozzy325is
Post Fri Nov 17, 2006 1:13 pm
any one smoked theres and allso what is the best conversion for brighter lights from scrappy i.e xennons or a bit weeker like them bright white/blue ones any help much appreciated
Steer Wit the rear!!!!
eko
Old timer
Post Fri Nov 17, 2006 1:17 pm
I smoked a set recently,well worth the effort IMO :)
You will need to make the crosses for the inner lamps though,Bazman on here has recently made a load of sets of these crosses,maybe PM him?
Im using Halfords homemake 100 watt rally bulbs in mine(not for road use?) and they seem ok for the money,bout £6 each.
HTH
fozzy325is
Post Fri Nov 17, 2006 1:20 pm
what paint did you use? and is that yours smoked in the pic?
karaokebykris
Post Fri Nov 17, 2006 1:22 pm
Gonna be smoking mine next week, should be fun! Gonna look good on my alpine weiss II i think. Will post before and after pics once i get it done.
It is meaningless to ask; which is real, 'real' or imaginary? It is simply a matter of which is the more useful description
"One valuable thing to remember is that light tavels faster than sound, some people appear quite bright until they speak
fozzy325is
Post Fri Nov 17, 2006 1:23 pm
nice one dude what paint you using?
karaokebykris
Post Fri Nov 17, 2006 1:26 pm
Gonna use some high temp matt black paint from local motor factors, used it before on my rocker cover and pleased with the results it gave.
Should I maybe use gloss or will the shine from the lense give enough depth?
eko
Old timer
Post Fri Nov 17, 2006 1:28 pm
They were a test set in that pic.
Since done another set which look much better,heres a crappy pic
I used Satin Black spray then used Black sealant to restick the lenses back on!
Also painted the headlight rings Black too while i was at it :)
