Washer Motor Not Working????
Yeti
my washer motor on my e30 316 is not working
i know the motors fine because i conected it straight up to the battery. is there any common problems with the motor or relays and which relay is it?
No common problems, no relays, and no seperate fuse!
Connect a 12V lamp between the purple/black at the pump and car body. Should light with the ignition switch at position 1 or 2.
If it does, then reconnect the plug to the motor, and short the brown/black to earth. This should make the pump run.
