simple q
will these fit a 325i sport allround??
would they be any benefit over normal 325 options etc??
Daz
m3 edc suspension setups
dazleeds
- old skool raver
www.oldskoolfantasy.co.uk
dazleeds
- old skool raver
Bttt
Demlotcrew
You would have to go five stud on the front,
But yes they will fit.
When working they are very good!
Andrew
Andrew
dazleeds
- old skool raver
what do you mean byDemlotcrew wrote:You would have to go five stud on the front,
Andrew
when working??
are these prone to not working then??
ecu and loom for these is also available
Demlotcrew
Yup you can still get everything to make it work.
They are still only dampers and after 15 years+ they are known to fail.
Dont think i will ever buy second hand dampers.
Andrew
Andrew
tobias
bear in mind that they originally had gas shocks and you cant tell if they are duds
also the lad on ebay has not listed ecu so you may win all four struts but he may then spank tou for ecu and loom.
that is of course if those are the ones your b idding on
jmc330i
What does the EDC thing do? Ive heard it mentioned, but know nothing about it.Demlotcrew wrote: When working they are very good!
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
Dan318-is
i think its electronic damper control mate. basically different firmness settings, i think there are three options? well rare i no that!
maxfield
comfort
normal
sport
normal
sport
tobias
correct
csl
When i was lookin for an M3,i tended to avoid the edc equiped ones cos i was told it was Ԛ£500 per corner if a damper failed.
tobias
495 plus vat..........ouch
Andyboy
- Alpina Colada
Avoid at all costs - it's shite. Like the E32 and E34 with EDC you have a choice of shit soft, standard or rock hard. When it was brand new it was sort of okay but an M3 was never a car in need of rock hard shocks to make it handle anyway. In fact they have have quite soft damping (Boge) as standard and a standard M3 handles and rides exceptionally well - better than anything Alpina ever made. You will also need the EDC loom which is virtually an interior strip and carpet out job to fit.
Just don't do it! Spend your money on some proper (Eibach) anti roll bars if you want an improvement in handling.
