In process of building m20 turbo aiming for approx 300bhp.
Will a standard 325i rad be ok or is there an alternative.
The car will be used mostly on track.
many thanks
Which Radiator for turbo conversion
blingsta
- Boost Junkie
i think every one that gone through with this mod has used a standard one.. mine is
Turbo-Brown
- Boost Junkie
Yep, mine's standard too
Stays between the quarter mark and under half on the gauge which is between 87degrees max temp and somewhere under 85 min
e30_Turbo
- Boost Junkie
I'm running stock too, fresh one but stock.
Ants stock too, as is D1MMY, Folwer, the baur beast & Dean....infact I can't think of anyone who has upgraded....
Toby is running the 535i rad but thats due to having the M30 lump.
HTH, Mark.
EDIT: Thinking about it Lennie had a different rad in but I think that was more a space issue than an item issue.
( P.s Lennies moved house and as yet aint got access to the net, he'll be back soon he said
HTH, Mark.
