k5 relay trouble ?? ( electric windows ) UPDATED
aled328
Post Wed Nov 01, 2006 3:21 pm
got round to re fitting electric windows this afternoon.
as always, not without its problems
getting power to fuse 28 ( so that windows work when doors open)
cant get any power to fuse 17 ( to eventualy to go to blue relay )
so .... bridged k5 relay at terminals 30 and 87.... got power.
changed relay for a spare ... dead again.
anything else to try??
cheers for any help.
Aled
aled328
Post Thu Nov 02, 2006 1:38 am
off to find an other set of relays in the morning. if anybody knows any thing that might be wrong apart from the fact I have a 2?? dodgy relays then please let me know.
cheers
Al
Post Thu Nov 02, 2006 9:22 am
There is a black/green wire to the starter motor that works the two unloader relays, K5 and K7.
If K5 doesn't work, then neither should K7 (heater fan and mirrors).
If K7 works and K5 doesn't, then the internal wiring of the fusebox has been got at.
aled328
Post Thu Nov 02, 2006 12:41 pm
cheers once again sir.
car does not have mirrors or a heater at the moment. :mad:
i will have a look for that wire and let you know how I get on.
cheers
Aled
Post Thu Nov 02, 2006 7:38 pm
The fuse box wiring should be fine, I checked it all out before it got boxed up mate
aled328
Post Fri Nov 03, 2006 10:52 am
ha ha, dont worry dan. :D
it seems there are more diffrences in the older engine loom.
bear with me on this one ( again !! )
This is the diagram from the 1989 loom, which is what you are talking abaout Brian.
below is what I actualy have.. looking at pin 15 the c101 connector on the car engine loom is empty.
any suggestions what will work best here ?
so.... any ideas on best way to go.....
Aled
aled328
Post Sat Nov 04, 2006 1:38 pm
:cry:
Post Sat Nov 04, 2006 1:51 pm
That's essentially the same thing. If it's wired as the second diagram it should work.
Turn the ignition on, earth the black/yellow wire and see if the relays pull in then.
DON'T work the starter while the black/yellow is earthed!
aled328
Post Sat Nov 04, 2006 1:56 pm
Thanks Brianmooore !
right, back off into the cold then !
will let you know if it works !
Cheers ,
Al
aled328
Post Sat Nov 04, 2006 3:16 pm
To let you know, I wired it as you suggested. All works perfectly.
so thats the leccy windows sorted then.
thanks for your help, again 8)
ABS , Heater and front lights to go !!!
Talk to you soon !! :wink:
Aled :D
