central locking n rev needle....
HUSSAIN
Post Sat Oct 28, 2006 11:00 pm
hi ive lost the central locking and also the rev needle has gone dead..
ive checked the fuses they seem to be fine..
any ideas what can be the cause to this problem??
zaust
Zone day release
Post Sat Oct 28, 2006 11:25 pm
Soundz like two seperate issues there.. Check the relay under the drivers side front speaker for the cdl, power any clicking sounds..
Rev counter could be many things. Start with checking the plug on the back of the clocks.
post your progress.
" Brian any suggestons"
M30 Tech 1 Touring on gas.
Post Sun Oct 29, 2006 11:31 am
Can't see any obvious connection between the two. They both use the same earthing point (above glovebox), but so do lots of other things.
Locking is fuse 28.
Instruments are fuses 21, 10, 12.
Tacho could be one of the first signs of SI board problems within the cluster, but I've found tacho's very sensitive to a poor connection on pin 9 of the bulkhead mounted C101 engine loom plug.
For the central locking, dig out the locking ECU from below the driver's footwell loudspeaker, and check, with a 12V 5W or 21W lamp (NOT a meter) for 12V across the red/black and the brown wires, then post again.
