tvs fitted in dash? visors?
P_VIDDY
just bought a dvd player and now need to find somewhere for screens, i want them in the front not in the headrest, any ideas?
Hadez
i have a dvd to and is in place for the stereo (normal place) i then got a flip out moniter basicly the same size as a normal stereo and fitted it where the center heaters are, took abit of building up at the edges because the heaters are alot wider. just a idea to put in the pot
miniblob
I've got a motorised screen that comes out the h/u.
http://www.dnrvinyl.co.uk/325touring/190806/
You could mount a smaller one at the bottom of the centre console at an angle - between where the ashtray is and the heater controls. I had an eq mounted there in a previous e30!
Other than that, depends how mad you wanna go on a build!! Use your imagination!!
Seen show cars with a motorised screen that comes out of the top of the dash.
Could build one into the dash/a-pillar where the bottom right of the windscreen is - seen a lot of people put sat nav in that position!
If you wanna rebuild the whole dash, build one in where the speedo etc is now and relocate the guages!!!
327 Touring with bass!!!
miniblob
Btw, might get a better response in the ice section!!!
Maybe get the mods to move this over there?
P_VIDDY
thansk for replys guys, much appreciated...
problem has now been solved and building began today
all shall be revealed with photos in a day or two
thanks again
thanks again
