M42 engine
mark_i
can an M42 engine from an e36 318iS be retro fitted into an e30.
Gortour
Yes, it's basically the same as the E30 318is, but 1.9 instead of 1.8. You may have different ratios in the back axle or gearbox depending on the E30 you're putting the engine into though. You may also need the wiring as this may be different in the E36
Bob_S
you will need to change the sumps on the e36 lump
the alternator bracket is different so that will need swopping.
Plus you only have one temp sensor on the e36 so you will need to drill and tap a new hole next to it so you have 2.
Then there is the EWS stuff which means a change of ecu and ignition barrel (2 keys = pita)
Also there is not TDC sensor on the e36's so you would have to change the timing chain case for the e30 one.
Personally I wouldnt bother and alternately find an e30 m42, easier said than done but there is one f/s on the zone
plus e36's used 2 engines in the "is" varient the M42 similar to the e30 and a newer 1.9 m44 engine in the later cars which was also used in the e46 for a short time I am lead to believe
Bollocks to this 24v scrap!
Royalratch
How tricky to fit that M44 to an E30?
