Does my 325i have lsd diff ?
moya
Post Fri Oct 20, 2006 7:06 pm
1988 325i e30 : what markings should there be on diff axle caseing to
show that theres a lsd.
Car is NOT a Sport.
Thanks for reading.
e30Pats
Post Fri Oct 20, 2006 7:18 pm
Can I point you to my thread with the same question
http://www.e30zone.net/modules.php?name ... ic&t=48203
Look at the tag attached to the diff.
EThreezero
Post Fri Oct 20, 2006 7:30 pm
It wont be a slipper if its the original mate, unless it was requested from new, cant see it. It'll have an S before the ratio numbers on the tag if it is indeed an lsd. Some still have a white S stamped on the bottom of the casing in paint or something, mine has at least.
*******MERC E240 BREAKING..1998...LEATHER...ALL PARTS*******
SPADGE
Post Fri Oct 20, 2006 10:46 pm
Jack the back end up and spin one wheel if the one on the other side spins the same direction then its a slipper.
Worth checking regardless of spec of the car as i recently had a 325 auto tourer which to my surprise had an lsd :)
Post Sat Oct 21, 2006 12:04 am
Wasn't standard on a 325, but was a fairly cheap option. Surprising that more 325s don't have them.
moya
Post Sat Oct 21, 2006 8:37 am
Great thanks to all who sent reply on limited diff question.
