Can I use a front seatbelt out of my touring for the iS?
not too bothered about access to the back seats (soon to be removed), just want to stop poor hammoj28 from bein splatted on the windscreen during braking maneuver
so just a straight swap then? obv using the bolts out the touringDanThe wrote:You should be able to bolt it to the same place on the seat, you will need the right bolt and washer though
cheers chris, but the ones in the touring are doing nothing at the moment.Chris-W wrote:Let me know if you need a 2 door seatbelt, Neil. But as Dan says, the bolt hole in the main pivot is the same on both types of seat.
