My car is fitted with an old Toad A200plus alarm,certificate for fitting is 1998 so fairly old although it does still work ok.
All the functions such as central lock/window closure/immobiliser etc work fine.
Problem is;since swapping the engine to M50,the indicators dont flash on the alarm either when switching on/off or when the alarm is sounding?
They did work/flash fine when i got the car!
Also there is a `valet` switch on the dash which obviously changing settings on the alarm,but no instructions in the Toad handbook as to how many presses and for what function,anyone know about this?
Should add,indicators and hazards work fine for driving just not for alarm.
Anyone?
Toad alarm Q?
ed325i
The valet mode has a diffrent code for each alarm so you will have to find out what the code is for yours which will be hard if you havent got it writen down.
It sounds like a wire is off or there could be an inline fuse that has gone for the indicators not to work.
