Nav there are six bolts two are only accessable with the roof half folded up. you will also need a flexible drive for your socket set as the front two bolts (of the four you can see) are inaccessible otherwise. Advice (to be taken lightly!!!) take the two front ones off that face foreward into the cabin that are only visible with the roof half folded, then using the flexible drive (or a worm drive it may be called) take the front two bolts then followed by the rear bolts. dont forgat to check if there are any shims under the frame before you take the roof off, mine had plenty, the donor car had none!!??
Note i did not actually get as far as removing the roof but this is how i planned it, but in conjunction with a mate to help with lifting it should be fairly easy. (i was lucky and found a cheap as chips replacement hood!!)
good luck
mr lee
