Subframe bolts
jmc330i
Post Tue Oct 10, 2006 10:16 am
The four bolts that hold the front subframe to the chassis (part Nos. 3 in the link below) are thay re-useable or are they stretch bolts?
http://www.realoem.com/bmw/showparts.do ... g=31&fg=05
Im pretty sure they are re-useable but just wanted to check.
James
'91 325i Sport
'93 318i touring 16v
Chris-W
Post Tue Oct 10, 2006 10:23 am
They're re-useable.
jmc330i
Post Tue Oct 10, 2006 11:47 am
:beer: :thumb:
James
'91 325i Sport
Andy335Touring
Post Tue Oct 10, 2006 9:08 pm
I had one of those shear off on me so i now use copper slip on those and the lolly pop bolts
Post Tue Oct 10, 2006 9:17 pm
Every body bolt needs copper slip!
Andy335Touring
Post Tue Oct 10, 2006 9:23 pm
Brianmoooore wrote:Every body bolt needs copper slip!
Amen
jmc330i
Post Tue Oct 10, 2006 10:32 pm
Copper slip????
James
'91 325i Sport
Demlotcrew
Post Tue Oct 10, 2006 11:02 pm
I thought they were stretch bolts?
Andrew
Post Tue Oct 10, 2006 11:11 pm
jmc330i wrote:Copper slip????
Or grease, oil etc
Demlotcrew wrote:I thought they were stretch bolts?
Only on the iS :wink:
jmc330i
Post Tue Oct 10, 2006 11:23 pm
Or grease, oil etc
:stupid: Yeah I just realised that :roll: :lol:
The iS has the same part number for the bolts as the 325i :?
James
'91 325i Sport
Demlotcrew
Post Tue Oct 10, 2006 11:24 pm
Hes taking the P I S S :piss:
jmc330i
Post Tue Oct 10, 2006 11:29 pm
Ok :?
So Im ok to reuse the bolts?
James
'91 325i Sport
Demlotcrew
Post Tue Oct 10, 2006 11:39 pm
Well i was told they are stretch bolts
there is a way to test them but it means buying some to waste.
I would just get new ones for the sake of Ԛ£4
When fitting the new/used ones grease up the caps.
Andrew
jmc330i
Post Tue Oct 10, 2006 11:43 pm
In that case I need new ones by tomorrow and that just isnt going to happen.
James
'91 325i Sport
Post Wed Oct 11, 2006 12:40 am
Just take the old ones to a fastners store as a pattern, im sure you will be able to get some to the right spec if not better
jmc330i
Post Wed Oct 11, 2006 2:38 pm
Whats the torque setting for the subframe bolts?
A good mornings work and the subframe has been changed :cool:
Had a bit of a fight with one of the bottom ball joints, but other than that it was pretty easy. All thats left to do is refit the wishbones to the struts and then tighten stuff up 8)
James
'91 325i Sport
