CAN'T REMOVE DRIVERS SIDE DOOR PANEL!!
hubble
Can some one help. I'm trying to the remove the e30 drivers door panel but the section where the toggle for the electric windows is won't come out. It seems screwed in. Have I missed another screw some where.????
d6dph
There is a screw behind the mirror toggle switch, pull the switch out to access it.
hubble
Have pulled off the toggle button, but cant see a screw??
d6dph
Two seconds and ill take a pic.
hubble
DONE SORTED FRIEND.!!
ian332isport
Not just the toggle button, you need to remove the complete mirror switch and unplug it's electrical connector.hubble1990 wrote:Have pulled off the toggle button, but cant see a screw??
Pretend it's not really a switch, and just like a plastic blanking plate like you have on the passengers side if you see what I mean
Ian.
d6dph
