Front wheel bearing kit
AJLintern
Post Thu Oct 05, 2006 10:24 am
Hi - first post here! :) I think my front left wheel bearing needs replacing - there is an audible humming noise from that area when driving over 40mph. I've looked on GSF car parts and found two types of bearing kit, one Ԛ£19.50 (part no: B40020A) the other Ԛ£39.75 (part no: B40020). Does anyone know the difference between these kits? Also is the hub nut included in these kits?
Cheers,
Andy
Ant
Retired Team Member
Retired Team Member
Post Thu Oct 05, 2006 11:45 am
the ABS cars use a bearing with a trigger wheel machined into them, they are more Ԛ£Ã”šÃ‚£ so maybe thats the answer dude ?
normally come with a hub nut, dont forget you'll need a 36mm socket for these bad boys 8O
Ziggy
Post Thu Oct 05, 2006 11:52 am
Aren't the 'A' Suffix items, usually just alternative / cheaper versions of the same part?
Ant
Retired Team Member
Retired Team Member
Post Thu Oct 05, 2006 11:57 am
could be, , GSF BQ parts are always O.E supplier, anything not BQ is poorly fitting chineese shite :lol:
AJLintern
Post Thu Oct 05, 2006 6:14 pm
Thanks for the replies - suppose I should get the expensive one really :roll:
