new battery....e30 or cosworth?
fuzzy
He who sleeps with "Gingers"
Post Sun Oct 01, 2006 1:40 pm
as above im needing a new battery but dont know whether i should go for an e30 one or a cosworth one due to the conversion. anyone know the difference in the two?
chu346
Post Sun Oct 01, 2006 1:54 pm
Do you know what the alternater puts out? Probably the same as a 325i one anyway.
Just get the biggest you can fit :D
fuzzy
Post Sun Oct 01, 2006 2:00 pm
chu346 wrote:Do you know what the alternater puts out? Probably the same as a 325i one anyway.
i dont have a clue about the alternator.i was just going to buy a big battery but wasnt sure if you can overdo it causing fuses to blow?
chu346
Post Sun Oct 01, 2006 2:05 pm
That won't happen.
I've had 3 batteries running before.
fuzzy
Post Sun Oct 01, 2006 2:12 pm
biggest one it is then :thumb:
fuzzy
Post Sun Oct 01, 2006 2:13 pm
chu346 wrote:That won't happen.
why 3 batteries? big ice install? :?
chu346
Post Sun Oct 01, 2006 3:15 pm
Yeah, I had a massive sony amp that should have cost Ԛ£3000 when I had my E46. the thing was about 40" wide 30" long but only 4" tall, big silver thing, it needed some juice.
aauser
Post Sun Oct 01, 2006 3:20 pm
Always better to have a bigger capacity battery than one too small, you will be safe that way
Post Sun Oct 01, 2006 5:20 pm
You need an E30 battery. It needs to be the right physical size, with the correct clamping arrangements, the right shaped terminals and terminals in the right place.
I buy the biggest one that will fit, which I suspect is for an E30 diesel, since I often use the car radio for entertainment at work and leave the boot open for hours at a time.
SPADGE
Post Sun Oct 01, 2006 6:18 pm
Fuzzy there are 2 types of alternators fitted to YB engines either 70 or 90 amp
HTH
Spadge..
fuzzy
Post Sun Oct 01, 2006 9:12 pm
Brianmoooore wrote: which I suspect is for an E30 diesel,
i didnt know you got an e30 diesel :?
thanks spadge does that rating correspond with the battery i buy,either a 70amp or 90 amp? :?
Post Sun Oct 01, 2006 9:26 pm
fuzzy wrote:[ does that rating correspond with the battery
Not in the slightest.
SPADGE
Post Sun Oct 01, 2006 9:35 pm
Havn't a clue mate just thought i would let you know what the alt ratings are.
tomtomiS
Post Sun Oct 01, 2006 9:42 pm
buy the biggest u can afford, ive got a 75amp heavy duty bosch one which ive had no probs with, i have ice which i often run without the engine on and ive never had battery probs. im sure i could get a bigger capacity battery in, i would like to, just dont got the cash
Post Sun Oct 01, 2006 9:43 pm
So whats the best way to determine the ideal size of battery needed?
fuzzy
how does the cosworth alternator output compare with the e30's are they about the same ? what are the relevant figures to compare when buying a battery? i think theres usually two figures on a battery,i think ones the cold cranking amps? :? whats the rating of the 325 e30 battery?
Post Sun Oct 01, 2006 10:23 pm
Just buy the biggest one that fits the battery tray, with the correct terminals, in the correct place, and the right way around.
A small independant tyre and battery place is your best bet, as well as probably being cheapest, the boss will probably take one look at the battery tray and come up with the right one.
SPADGE
Post Sun Oct 01, 2006 10:26 pm
fuzzy wrote:how does the cosworth alternator output compare with the e30's are they about the same ? what are the relevant figures to compare when buying a battery? i think theres usually two figures on a battery,i think ones the cold cranking amps? :? whats the rating of the 325 e30 battery?
Its a shame your so far away mate as i have a brand new heavy duty brute of a battery that i removed from one of my E34 donor cars. They fit perfectly in the touring battery tray (just) and will be plenty man enough for your YB engine and anything else you want to wire into the car!
Post Sun Oct 01, 2006 10:30 pm
And make sure it can be bolted down!
A car overturned right at the end of our lane four weeks ago, and demolished a telephone pole. No serious injuries, but the next day it was found that the battery had been flung out of the car, right over the roof of a building, and straight through the roof of a touring caravan. I pass the caravan every day - nice clean battery sized hole in the front curved bit of the roof, with clear plastic taped over it.
