Front suspension top mount
Bmw appear to list two top front suspension mounts as being available for virtually any model (I have looked at 318 is - 325i). One is listed as standard (part number ending in 452), the other as being for a camber correction of '+-30 min'. Does anyone know what model the camber correction item would be suitable for?
- Brianmoooore
Or bented325i wrote:You would use the camber correction if the car was lowerd.
ed325i wrote: I think some M3 had them fitted. They can be fitted to any e30
or if you want more camber, but +/-30min = +/-0.5 deg isn't worth much for more (negative) camber
(running -4Ԛ° camber on front left wheel and still getting wear on the outside edge, but its getting better...)
calder
