Starting problems - Part 2
Tux
Post Thu Sep 28, 2006 10:03 am
Back in May, my car failed to start a couple of times.
When I turned the key, the dashboard lights would come on, but no starter (battery seemingly OK). BrianMooore suggested I tried starting the car by jumping two pins in the diagnostic socket, in case it was a dodgy ignition switch.
Well, having Tipexed around the pins, and kept a bit of wire in my car, it never re-occurred. Yesterday, itâ┚¬Ã¢”ž¢s started doing it, and now itâ┚¬Ã¢”ž¢s happening regularly.
If I turn the key, I get a click from the solenoid, but no starter motor. If I jumper the two pins on the diagnostic socket, itâ┚¬Ã¢”ž¢s just the same. Do it a few more times, and the engine starts.
Apparently the previous owner had a similar problem, and replaced the starter motor (used one I think) about 2 years ago. Any ideas? Are there any relays I should replace?
yz_250
Post Thu Sep 28, 2006 10:12 am
mine did the same a wail ago ...but turn out to be a worn egnition so i slaped in a push button and it was sorted but you say if you brige you stater it doz not start ?....so your egnition sound ok
"Sorry under the influence of driving in style"
Tux
Post Thu Sep 28, 2006 6:41 pm
I have checked the cables to the starter, and they are all secure. There are 3 wires connected to the starter, one of which is a thin black wire - what is that for? (looks a little bit ropey, but ok I think).
Where is the engine earth strap located?
