Slow fuel filler
Treeman612
Post Fri Mar 18, 2005 8:34 pm
Am I the only guy having problems filling up with juice on my 320i 1989 4 door saloon?
It's so bad at Tesco, I often 'time out' the pump and have to start again. I know the tank is midships, so filler neck is long, but is there a breather somewhere which may be blocked?
Any more than about a trickle of fuel at a time and it coughs back out!!??
6potWil6pot
Post Fri Mar 18, 2005 10:26 pm
How do you mean? The pump clicks and stops you filling up? Even thought you can clearly get more fuel in?
Mine does that from time to time but i just take the pump most of the way out the funnel and just squirt fuel in!
vroooom_ptssssh
Post Sat Mar 19, 2005 12:32 am
sounds like the breathers blocked, not a clue where they are on E30s sorry.
Post Sat Mar 19, 2005 1:58 pm
There are breathers from the tank to the top of the filler neck, (they all run behind a metal plate inside the rear right wheel arch), but the only one that vents to outside runs under the car along side the two fuel lines and should end with a bit of rubber pipe pushed inside the reinforcing section of the front left suspension turret.
Treeman612
Post Sat Mar 19, 2005 8:34 pm
Cheers, Brian, will check out front breather in morning
Templ8e30
Post Sat Mar 19, 2005 9:43 pm
The filler neck tube to the tank can collapse on the e30 sometimes, and it can delaminate so it looks ok on the outside but is buggered inside :roll:
Give it good squeeze and see if it feels uneven along its length.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
