318iS Suspension
JohnH
Post Wed Sep 27, 2006 10:42 am
Can anyone recommend springs and shocks to replace the standard ones in an iS which are old and knackered?
John
eamo
Post Wed Sep 27, 2006 12:27 pm
billies and eibachs boss!
tried and tested but everyone has there own personal tase
the hr cup kit in the zone shop looks good too!
iDreamBeemer
Post Wed Sep 27, 2006 2:46 pm
I went for H&R springs bilstein shocks to get 35mm drop. Real happy and also sorted though Zone shop
JohnH
Post Wed Sep 27, 2006 4:30 pm
eamo wrote:billies and eibachs boss!
That's what I reckoned but I thought I'd throw it out there.
eamo wrote:the hr cup kit in the zone shop looks good too!
I think it would make it too low - it's my gf's daily driver and doubling as my toy - she doesn't always slow for speed bumps so I don't want to make it too low.
iDreamBeemer wrote:I went for H&R springs bilstein shocks to get 35mm drop. Real happy and also sorted though Zone shop
What's the difference between Eibachs and H&R springs? The drop is the same but the price is different...
Bob_S
Post Wed Sep 27, 2006 5:32 pm
she doesnt slow for speed bumps? I wouldnt lower the car then! could be a few cracked sumps then!
I'd recomment H&R springs definately
I personally run koni shocks which I like but the general opinion is that billies are better suited? I cant really comment as I've not used billies
Bollocks to this 24v scrap!
kevin316i
Post Wed Sep 27, 2006 10:15 pm
It's difficult to find a better sports suspension than the MTEC setup, as it gives a decent amount of comfort that you won't get with others. I think this is important, especially in Ireland with all the crappy roads we have. If the springs are in good nick, get a new set of Boge MTEC shocks from eurocarparts. If the springs are crap, new ones are very expensive from BMW, but you could consider Eibachs.
You will be surprised the improvement you will notice with a new set of Boge MTEC shocks.
MikeeMiracle
Post Wed Sep 27, 2006 10:51 pm
I've not got experience on an E30 but the H&R springs tend to be on the harder side while the eibachs tend to be softer and more suited to brittish roads. I had H&R's on my Civic Type-R and rate them very highly but if your girlfirend doesn't slow down for speed bumps then the eibachs are probably the better route for you.
I bought an 318iS a few months back which already had the suspension replaced with the standard MTEC stuff, it loads up very nicely on the corners and is also very compliant over the bumps. I normally take them at 30mph without too many problems and only have to slow down to 20mph for the bigger speed bumps.
Red 318is
Take me to the land of the twisty's :)
Pal318is
Post Wed Sep 27, 2006 11:07 pm
I have a set of eibach's with koni shock's, which give a decent ride, BUT i would like some bilstein shocks next, they seem to come highly rated.
Pal
Pal
Image[img]http://Image
MikeeMiracle
Post Thu Sep 28, 2006 12:48 am
Again they are meant to be stiffer than the "default" Koni choice.
Red 318is
Cava
Post Thu Sep 28, 2006 1:34 pm
I'm getting my car sorted with brand new o.e. mtec stuff next week - I'll let you know if it was worth the expense!
JohnH
Post Thu Sep 28, 2006 3:19 pm
Thanks Cava
M5pilot
Post Thu Sep 28, 2006 4:46 pm
I've been in a car with brand new Mtec stuff.
It is actually very good but sits way too high and the car still boats around too much.
The Eibach springs are softer than the H&R, the difference in price is simply down to the what the distributers want to charge here.
I would go with Bilstein shocks and either of the Eibach or H&R springs.,
The Alpina C2 has 35mm H&R's and Bilstein sport shocks -very nice ride and ery good mannners in the bendy bits.
Sal
Cava
Post Thu Sep 28, 2006 8:27 pm
I would have loved to have gone with the eibach / bilstein combo but i'm using the car daily and it has to contend with my garage ramp and speed bumps so I've decided to stay stock. Might try this combo on my other car though - I fancy setting it up for track day use.
M5pilot
Post Thu Sep 28, 2006 8:42 pm
The Eibach and H&R springs only lower a sport by a mere 10-15mm.
Still very practical.
Sal
Cava
Post Thu Sep 28, 2006 8:57 pm
I already had the replacement stock shocks in the garage so i was a bit limited as far as buying lowered springs with matching shocks. :(
tim_s
Post Thu Sep 28, 2006 9:16 pm
+1 for konis
Used billies in another car about 5 yrs ago, they were fine too, i like the adjustability of the konis though.
2.1 318is, MS, LPG. 200bhp, 175ft/lbs GONE!
Boxster, e46 m3, e36 sport touring and alpina B3 3.0
Morat
Post Thu Sep 28, 2006 9:35 pm
would stock MTEC shocks handle the 10-15mm drop of Eibachs or HnR?
Post Thu Sep 28, 2006 10:19 pm
probably but they wouldn't be 100% ideal but that depends on your requirements.
i've been in/owned cars with all the setups mentioned and found that they are all good, but the m-tech setup isn't a touch on the H&R/billy eibach/konis setups when it comes to the bends as the limits of these combos are so much higher.
I've also found that the eibach/knois setup can if u want have the best ride with there nothing in it between the other 2.
2p!
my favourite is billys and H&R's
No car should take speed humps at 30mph that is not good for suspension
