not sure if tis is the right place, just bought a tom tom one to replace my hp1710 ipaq sat nav, has anyone got one if so any ideas on mounting it.
dont want to use the window sucker thingy , also do not want to have screw holes, currently just put it in console by the ash tray moves about a bit but easy to put away. any ideas would be appreciated
thanks
tom tom one
billgatese30
can you get an exteranl antenna for it, as if its mounted down there then it will probably not be able to pick up the satelite signal withough a seperate antenna
Bally
it works fine , you can get antenna for it but its ok as it is just slides about
