waxoyling
- gooner1
- Out humping Reindeer
Intend to waxoyl my cab some time this week, need some advice from anybody that has done this before i.e best places.In side doors obviously but where else that is easily,or not,reached.While im here how can i re-align my steering wheel,just cant get it right and its driving me nuts
TO do it well, you need to sprip out all the boot carpets, then spray it everythere!
Take the sill covers off and spray into all the holes you can see, but only enough to cover the surfaces as the sils have dranage points under the car and if these get blocked it could cause rust longterm.
Then take the rear door cards out spray it all in there.
The best stuff is from BMW and costs Ԛ£10 it will do most of the car.
Andrew
Andrew
- thebigone
Hi, try to get hold of a lenght of flexi tube that wil fit over the end of the nozel that you are useing. put a bung at the end of the tube and make a serias of small holes in the tube so it will spray the wax out in a fan pattern 360deg, then as you spray pull the tube back out of the sill you will get better coverage this way
dont get it on you. its sticky shit!
im so sexy justin brought me back 5 times
- gooner1
Andrew you would,nt have part number or code would you,only just rang dealers and they say all they do is wax.Demlotcrew wrote:TO do it well, you need to sprip out all the boot carpets, then spray it everythere!
Andrew
