TPS
gooner1
Out humping Reindeer
Post Sun Sep 17, 2006 9:56 am
Has any one managed to replace the TPS switch on the throttle body without actually removing TB from the car?.Only ive just managed to sort my coolant temp probs and really dont fancy draining and bleeding again.
Post Sun Sep 17, 2006 10:38 am
You can take the TB off without disconnecting the water pipes, but you can access the TPS and it's screws by removing the convoluted air hose.
You don't have to drain the coolant to disconnect these pipes anyhow - they're just about the highest part of the cooling system.
gooner1
Post Sun Sep 17, 2006 4:23 pm
Thanks Brian, TPS now fitted and car idling at 800 rpm also temp now moving out of the blue.Mmmm wonder whats next :)
