Motorsport goes dead!
w17led
Post Sat Sep 16, 2006 10:09 am
Hi Chaps,
Need a bit of advice,
Had my car booked in at a garage to do my alternator housing bolt as one had snapped off and needed a easy out tool.
Quite simpe really, take the bolt out and put a new one in.
Picked up the car a few days back and drove it home. The next morning went for a drive and after about 15 min, the battery light came on!
Then the car started to loose power. Now everytime i jump start the car it starts, and then dies after 5 min.
COULD the garage have done something to the alternator so it does not charge the battery or is it just chance that the alternator has now gone or battery finished?
Any response and advice will be appreciated
thanks
Post Sat Sep 16, 2006 10:12 am
sounds like the altrnator has had it to me
w17led
Post Sat Sep 16, 2006 10:26 am
thats what i think.
sounds dodgy as it was fine before it went to the garage?
Looks like i will have to get one and give it a go
E30Mark
Post Sat Sep 16, 2006 10:35 am
check the battery / alternator connections are tight, if you have a volt meter check the voltage at the battery when the engine is running, it could be the battery that has died, check the acid levels in the battery if accessible.
PM for details
