I've seen a few photos out there showing E30s with the rubber rub strips (on the doors) painted to match the body colour.
Anyone on board ever try that? I'm assuming that because they're soft, that some sort of flex agent would be necessary to prevent the paint from cracking the first time it gets whacked.
Any thoughts/experience?
Painting Door Rub Strips
KDS
-KDS in Vancouver ('88 325i Touring)
khan325i
hi there i dont no if this is any help but there is a thing that you add to paint befor painting on to soft plastick but i dont no what it is called
hope this helps
hope this helps
Borderbmw
You either use a plastic primer,or plastiser to the paint,but it can only be added to 2k paint,so if you doing it home the plastic primer is the safest and easiest way mate.
valver
i did my rear spoiler with plastic primer and paint from the dealers and it looks cool
johnono
would be smart to have a solid colour without the break-up, but if someone opens a door on you thats the first thing itԚ´ll see
and i wouldnt want to be you when you come back to the motor to see what somme lemmon has gouged in your door
