im putting together the parts to put an eaton m90 supercharger kit on my 2.7. My question is can i use a non heated O2 sensor ie a one wire lead, to run my air fuel gauge?
will i end up getting a ton of build up on the sensor or will the exhaust heat burn it off?
i should add as of now i will be using a narrow band gauge and sensor to get the car to rough tune then later will dyno and wide band sensor.
thanks for any help
O2 sensor question
bottlecapE30
1987 2.7l e30 m20b27 supercharging
1991 3.5l e30 m30b35 it is dead so sad
1985 3.5l e23 m30b35
