Best brake fluid. recommendations please!
oguz327
Captain Armco
Captain Armco
Post Thu Sep 07, 2006 6:08 pm
I need to do a brake fluid change/ upgrade.
What do you folks use/recommend for fast road/track use?
Oz
maxfield
Post Thu Sep 07, 2006 6:09 pm
Is it dot 4.1 or 5.1 that is suppose to be one of the best
DRIFTBOY
Post Thu Sep 07, 2006 6:17 pm
Dot 4 is fine for most cars on the road and track and won't need changing often - unless you do manage to boil it!
Dot 5 has a higher boiling point but is more hydroscopic (it absorbs moisture more) so will not boil as easily but will need changing more often.
GDBN
Post Thu Sep 07, 2006 6:39 pm
ATE Super Blue is quite good.
G
Theo
Post Thu Sep 07, 2006 6:42 pm
Oz, what pads did you go for? Think I better put some good pads in...
oguz327
Captain Armco
Captain Armco
Post Thu Sep 07, 2006 6:46 pm
Theo325 wrote:Oz, what pads did you go for? Think I better put some good pads in...
Cheers for the sugestions, keep um coming.
Theo, still havnt done the pads yet dude, gonna do all the brakes in one go but when i do ill go for the mintex ones, forget the code now.
Get your done as well fella, gonna need the xtra me thinks winkeye
Theo
Post Thu Sep 07, 2006 6:50 pm
Sweet, just started reading up, from what I can gather ferrodo or mintex are the way forward.
Will be interesting to see how much faster your sport is than my barge, you've got a fair few trick bits under the bonnet haven't you?
Demlotcrew
Post Thu Sep 07, 2006 6:53 pm
Oz just use ATE super blue, its more than good enough for what we are going to use it for.
Plus its only Ԛ£10 a litre so its good value for money.
I think the pads would fade before the fluid does.
Andrew
oguz327
Captain Armco
Captain Armco
Post Thu Sep 07, 2006 6:57 pm
Sounds good at a tenner, where do i get it from Andrew?
Demlotcrew
Post Thu Sep 07, 2006 7:06 pm
Euros sell it, thats the best place.
Andrew
Jon_Bmw
Dangerous when thinking
Post Thu Sep 07, 2006 7:58 pm
Yep, that stuff has a good repuatation. Alternatively there is Motul RBF600 i think, also for around the same sort of money.
Dan318-is
Post Thu Sep 07, 2006 8:04 pm
Jon_Bmw wrote:Yep, that stuff has a good repuatation. Alternatively there is Motul RBF600 i think, also for around the same sort of money.
ditto homie
GDBN
Post Thu Sep 07, 2006 8:34 pm
You putting in proper hoses too?
Just ordered some from Sal.
G
stuartgallafant
Post Thu Sep 07, 2006 10:49 pm
DRIFTBOY wrote:Dot 4 is fine for most cars on the road and track and won't need changing often - unless you do manage to boil it!
i dont mean to pick holes, but this isnt true. brake fluid, no matter what rating, must be changed at a maximum of two years. higher DOT ratings need changing more frequently. Yes, DOT 5 does absorb more water, in which case, it will boil more quickly. Brake fluid has a higher boiling temperature than water (at something like 170 degrees C), therefore, any water in the lines will boil rapidly, inducing brake fade.
another reason you should change your brake fluid at recommended intervals, is because water in the lines will cause your components to rot. everything in the brake/clutch line is made out of special materials resistant to the effects of brake fluid chemicals. however, water contains harmful compositions that destroy these materials.
when changing the brake fluid, the clutch fluid must also be changed (there is a bleed nipple on the slave cylinder). E30's have a common problem with slave/master cylinders, and this is a big part of the problem. the system is neglected, water penetrates it, system fails!
sorry if i went off a bit there, i was concentrating too hard!!
Davenotouring
Post Thu Sep 07, 2006 10:57 pm
Useful info!
Castrol SRF is my choice, but might change to Motul cos it's too pricey! :eek:
BMW 328i Cab - Daily Slag
andyp
True Old Skooler
Post Thu Sep 07, 2006 11:10 pm
Davenotouring wrote:Useful info!
sorry quick hyjack
Notouring you got my stuff yet, try and get them signs up plz as i cant do it as it will not work. cheers.
O yes dot 4 brake fluid is fine
FBF
Post Fri Sep 08, 2006 12:11 am
my advice is to buy the cheapest.
im so sexy justin brought me back 5 times
oguz327
Captain Armco
Captain Armco
Post Fri Sep 08, 2006 12:30 am
FBF wrote:my advice is to buy the cheapest.
how come?
jamesc
Post Fri Sep 08, 2006 12:37 am
Demlotcrew wrote:Oz just use ATE super blue, its more than good enough for what we are going to use it for.
Andrew
Easy to bleed as well - just wait till the colour changes.......
James
FBF
Post Fri Sep 08, 2006 8:09 am
how come?
cos you wont notice the diffrence... do you have uprated pads disks and hoses? if not then go with the cheapest.
ian332isport
Post Fri Sep 08, 2006 9:33 am
Just to clarify...
Dot 5 is a silicone based fluid that is not hygroscopic. It's generally used on classic cars that sit for a long time. It's not generally compatible with regular brake fluid, and should never be mixed.
Dot 5.1 is the stuff that's like regular fluid but with a slightly better spec than Dot 4. This is hygroscopic and does need changing on a regular basis.
Ian.
Gwynleym10
Post Fri Sep 08, 2006 9:36 am
Isn't DOT 5 completely different to DOT 5.1? We shouldn't use DOT 5 as its got silicon in it or something and will stain the braking system? Maybe wrong but i'm sure there is something a little confusing about brake fluids and their DOT numbers.
Also always use new brake fluid, don't use something from an open container as you might as well not bother changing it.
Gwynleym10
Post Fri Sep 08, 2006 9:38 am
Ian got their before me.. :mad:
Dual wheel carriers -------195litre Fuel Tank
London 2 Cape Town
www.Overlandinthesun.com
Tom944
Post Fri Sep 08, 2006 9:56 am
I recommend ATE Racing Blue also. Greater feel, no fluidheat fading and great value for money.
E30 M50B25 racer soon-to-be E30 S50B30 racer
stuartgallafant
Post Fri Sep 08, 2006 3:17 pm
i changed miniblob's brake fluid with some funky purple shit that sal gave him. that was quite good
Sinha
Post Fri Sep 08, 2006 3:56 pm
changed from dot 5 to wilwood race fluid... I have wilwood 4pots on the front on 280mm disks... at low speed I couldnt tell any difference, but on track or whenever taking a big beating, you could then definately tell them apart... I can kick the living shit out of my brakes at speed now without any signs of fade (my car is stripped so lighter too)... But unless you'll be driving fast/late breaking etc then dot 5 will do... apparently you can get good detergents to use after bleeding to clean the system before putting the new stuff in. Sounds like a plan, because race fluids/silicone based stuff mixes VERY badly with other fluids...
hope this helps..
miniblob
Post Sat Sep 09, 2006 6:22 pm
stuartgallafant wrote:i changed miniblob's brake fluid with some funky purple shit that sal gave him. that was quite good
Ha ha, that was castrol SRF - expensive, but i could feel a massive improvement over the old standard fluid!!
Did we change my clutch fluid at the same time Stu??
327 Touring with bass!!!
stuartgallafant
Post Sun Sep 10, 2006 5:21 pm
no mate, we ran out of fluid, and i said i'd get some normal brake fluid for ya! will do that at the next service for you
Chris
Post Sun Oct 22, 2006 11:37 pm
So is it allright to use DOT 5.1 Synthetic base in my E30's system?? I'm worried now.
The system is gonna be emptied when i do the brake lines and i was gonna then fill it up with this stuff.
ian332isport
Post Mon Oct 23, 2006 9:57 am
thedingbat wrote:So is it allright to use DOT 5.1 Synthetic base in my E30's system?? I'm worried now.
As long as it's 5.1 and not 5.0, you will be fine.
