erratic idle on 318iS
ChizFab
Post Tue Sep 05, 2006 7:56 pm
starting from cold my iS can be dodgy on idle and has cutout couple of times.
thought it myt be a cold start valve type dealy but im new to beamers so thot you zoners myt know?? fuel pressure?? :?
tim_s
Post Tue Sep 05, 2006 10:32 pm
no cold start valve per se, but there's an ICV (idle control valve). to rule it out, simply unplug it. a diag would be the best place to start really, our cars have the most up-to-date motronic of the e30s and a proper diag can normally tell you what's up. I'd say coolant temp sensor would be a good place to start, mb even TPS.
2.1 318is, MS, LPG. 200bhp, 175ft/lbs GONE!
Boxster, e46 m3, e36 sport touring and alpina B3 3.0
P_VIDDY
Post Tue Sep 05, 2006 11:14 pm
does it idle funny wen warm as well or just wen cold? if it does it most the time check ur pipes for air leaks as these always rot
ChizFab
Post Wed Sep 06, 2006 8:06 pm
just when cold chaps.
cheers il have a look once the mots done.
