Hi guys
Will a large case diff fit in place of a small case item in a touring or will i need to change the rear beam? Also, are the drive shafts from a 318 touring (small case diff) the same size as the ones required to fit a large case diff??
Cheers Spadge..
diff swap - small case to large???
SPADGE
Chris-W
stuartgallafant
SPADGE
Nice one fella's just the answer i was hoping for
Propshaft will be getting more than 'moved slightly' it is getting replaced with an M3 item as this is for my M30 conversion
