320 exhaust
ed325i
Post Fri Sep 01, 2006 3:53 pm
Can you get a rear 320 box with twin tail pipes ?
jmc330i
Post Fri Sep 01, 2006 7:47 pm
The facelift 320i does have twin tailpipes.
I think the early ones have singles, but Ive also seen some with twins.
James
'91 325i Sport
'93 318i touring 16v
ed325i
Post Fri Sep 01, 2006 7:52 pm
Do they have the single inlet pipe.
handpaper
Post Sat Sep 02, 2006 3:09 am
My '89 320iSE is twin-pipe from the manifold to the exit. I put a Powerflow stainless system (secondhand, eBay) on simply because I couldn't find an aftermarket supplier (Bosal etc.) and an OEM one was c. £400.
Templ8e30
Post Sat Sep 02, 2006 9:48 am
The early 320i has a single pipe system but the facelift 320i has a twin pipe system all the way through.
You could upgrade the whole system to the facelift type.
It'd cost a couple of hundred quid to get all the parts from GSF or eurocarprats.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
koos
Post Sat Sep 02, 2006 8:53 pm
Mine is a 1991 320i and it has twin pipes from the manifold back, fitted a 325i scorpion backbox, a bit tight but it did fit, sounds goooooood!!
