Can I use my wideband lambda to get the fuelling close enough to get through MOT emissions? The probe is in factory location, at the 2-1 of the exhaust front pipe, reads about 16:1 at the mo, not sure if i should richen up a bit before the MOT? suggestions and experience much appreciated!
tim
quick wideband lambda question/emissions
tim_s
Ant
- Retired Team Member
How is the idle ? if its smooth and stable, I'd suggest the mix is OK, Malcs is 16:1 @ idle and smoother than stock
you may have to tweak the timing to reduce the HC content though, how does she smell? sickly sweet is high HC( as a rule, always exceptions ), no real noxious stink, probably ok and around 440 ppm.
if you're worried, take the laptop with, and ask him to test the emissions manually 1st, then log on to test
HTH
HTH
Email FTW
tim_s
