TWO THINGS I DID , NOT SURE WHICH ONE WAS THE CURE,
FIRST WAS THE 3 METAL ELBOWS THAT ARE PRESS FITTED INTO SIDE OF THROTTLE BODY , THEY HAD BECOME A LOOSE FIT , BIT OF SEALER ON EACH ONE AND BINGO NO MORE VAC LOSS....
SECOND WAS INSPECT THE TRACKS INSIDE THE AIR FLOW METER,
THIS I DID BY CAREFULLY PRISING OFF THE SQUARE PLASTIC COVER
ON TOP , I LIGHTY PUSHED THE NEEDLES ONTO THE TRACKS FOR
MORE CONTACT ....
I ONLY DID THE SECOND PART COS I HAD A SPARE A.F.M , YOU MAY
NOT ....SO BE GENTLE ! ! !
IF YOU DO THE SECOND PART MAKE SURE SHE RUNS OK BEFORE
GLUING THE LID BACK ON ! ! ! GOOD LUCK , JIBBERS
P.S. THANX TO SIMON AND GLENN FOR INPUT .
CURE FOR BAD IDLING
- webbyv7slipperwagon
What do you mean by bad idling? just rough or hunting up and down the revs?
320Touring
jibbers, on forums, writing in capitals is regarded as shouting!
just use lower case, unless forming sentances/paragraphs when a capital is required
tis, cool!you're not in trouble
