exhaust is fine, no knocks
topmounts, a bit of movement, but tbh well within what the should be moving, no knocks either..
when i went to move the jack tho, it made a solid metallic knock on the metal at the side while in its holder, gave it abit of a shake and sure enough it started knocking away happily, so ive wedged my map down the side of it to stop it hitting, and ill guess we will see in due coarse if that was infact the knocking
im up the garage on sunday so i can have proper little mosey undernethe then..
