launch control
m30e30
Post Wed Aug 23, 2006 5:24 pm
im toying with the idea of putting launch control on my bimmer they say it runs off of the abs sensors has anyone here done this or will i be the first
i dont have abs do standard hubs have abs fitting brackets
the launch control also comes with tracktion control so when its all done it will have
abs
tracktion control
and launch control
Ant
Retired Team Member
Retired Team Member
Post Wed Aug 23, 2006 8:16 pm
fit an Ms ECU dude, not only can you ditch the AFM and remap to any mod you may dream of, it has a launch control and traction control dongle that allows you to set max rpm/time om a scale, then if rpm increase beyond what you set @ any time, the ign timing will be pulled back to rein in the spinning wheels/slipping clutch etc.
Launch control is a clutch switch or PTM switch on the wheel, you set max RPM with the switch made, tehn until you release it the rpms will not exceeed what you originally set.
sounds complicated ?? trust me its easy to implement, and more time spent toying with it the better the outcome, cheap as chips too.
Just an idea.....
stuartgallafant
Post Wed Aug 23, 2006 8:21 pm
i think it would be easier to learn how to drive better?!
