brake lines
spook
League two here we come !!!
Post Tue Aug 22, 2006 6:14 pm
my brakelines on my 325i are getting a little bit dodgy and will need replacing soon, can you guys tell me does the goodridge kit contain all the parts needed to do the job, and the garage i USED to use reckoned the back axle needed dropping to do the job, SURELY HES HAVIN A LAUGH many thanks spook
dobbie82
Location: Dolgellau, Wales (NOT A TRADER,broken a car,got lots of bits)
Post Tue Aug 22, 2006 7:03 pm
Nope he's not having a laugh, just a quick giggle. the axle doesnt need to come out but the diff will need to be dropped to replace the bit that splits into left/right, the fuel tak has to come out too iirc...
not a fun job
e30 related ebay auctions + shop(MY Stuff for Sale), http://tinyurl.com/64aufr
My Feedback on the e30zone: http://tinyurl.com/dobbie82feedback
chu346
Post Tue Aug 22, 2006 7:05 pm
That's why I sold my kit :D
spook
Post Tue Aug 22, 2006 7:12 pm
so its an expensive job then chaps
jamesc
Post Tue Aug 22, 2006 7:33 pm
You don't have to remove the fuel tank but you may have to drop the subframe if your brake lines are in a bad way.
Mine were so rusted I had to cut them off, luckily I had the subframe off to do all the bushes so had plenty of access.
Very rusty:
James
Davenotouring
Post Tue Aug 22, 2006 8:12 pm
Any lines like that will be an MoT failure at a reputable garage, if anyones are like that I suggest replacing as many as possible at the same time.
Brake pipe is about £2 a metre and the ends are about £1 each. It is just the flaring that you need a tool for, and the time taken to replace them.
BMW 328i Cab - Daily Slag
Templ8e30
Post Wed Aug 23, 2006 10:41 am
The Goodridge kits have everything you need to fit them BUT please make sure you get the correct kit !, the Goodridge kit description is wrong.
If you have rear drum brakes you need the 4 line kit, if you have rear disc brakes you need the 6 line kit regardless of whether you have ABS or not :mad:
Cheers,
Iain T
2007 Mazda 6 2.0 estate
