hmm, not too sure about the gearbox's not workin, i did the conversion on mine almost 2 years ago now, still using the 2 litre prop, clutch and diff and only looking to swap the diff cause i want a drift slag LSD!
its been well and truly hammered since to be totally honest. not to discredit you calder, you may have had something i havnt come across or i might just have been damn lucky! the only trouble i have ever had is from a busted rocker or two, but i put that down to limiter bouncin! lol,
all you need is about 8 hours if your a halfway decent mechanic with a mate and a crane. provided you dont get anything daft happenin. just make sure you get the AFM, ECU (from the 2.5 cause a 2 litre one doesnt work very well!) , oil cooler and all the other ancillaries and it is just a straight swap. undo it, refitting is a reversal of removal. would recommend re tapping the manifolds and replacing all the studs and bolts on both sides cause its much easier when the head is out and makes it easier in the future. change the cambelt cause that pish easy with the lump out and clutch if you really want it to get picky. i personally just went for it! but then i am a bit of an impatient git when i get excited!
but all in all, dead easy job, bonnet off, undo everything, rad out, exhaust off, undo prop, let the box supports off and let the gear stick stuff off, crane and hoist it out, with someone standing on it if you leave the box attached!
at least thats how i remember it, strange, its all a bit fuzzy now! Lol, still, be doing a 2.7 turbo swap out in a couple of weeks, bit of a refresher!
all the best and hope it goes well if you decide to go for it! its so much fun if you do!!!!
http://media.putfile.com/rollin-burnout
