hi: guys
i've just spent my evening trying to start my touring but it wont
i've swapped my leads,distributor,rotor arm and i cleaned the crank sensor ! still it wont fire up
theres plenty of petrol in tank and the idle control valve hums when ignition is on so its ok
i checked plugs for spark but its not sparking
only thing now i can think of is ecu or crank sensor
i disconnected the ecu and reset it still theres no spark and i gave the crank sensor a good clean using wd40 still nothing
pls help!
325i touring not starting
Templ8e30
It does sound like the crank position sensor.
I got one from eurocarprats for £40, it's a genuine Hella part too.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
jonbuoy
