engine cuts out?
mark320i
Post Sun Aug 13, 2006 12:12 pm
started the engine up for the first time yesterday and a bit of trouble, went from a 2.0 to a 2.5, when you let the revs off the car cuts out?
could it be air flow meter or ecu maybe?
cheers
mark320i
Post Mon Aug 14, 2006 6:37 pm
anyone?
kam-325i
Post Mon Aug 14, 2006 6:39 pm
Are we talking M20 engine here ?
mark320i
Post Mon Aug 14, 2006 6:41 pm
yeah mate m20 2.5
kam-325i
Post Mon Aug 14, 2006 6:47 pm
same eninge as mine......
i would look at the FPR first.
mark320i
Post Mon Aug 14, 2006 6:53 pm
fpr? sorry
kam-325i
Post Mon Aug 14, 2006 6:57 pm
Fuel Pressure Regulator, It sits on top of the Fuel injector rail, near the Thermostat housing.
Dose you engine cough and spluter untils it dies or is it sudden death ?
Ant
Retired Team Member
Retired Team Member
Post Mon Aug 14, 2006 6:58 pm
2-5 afm, intake and fuel rail ??
if thats not the case, find em dude, you're gonna need them
engine earth strap refitted ok ?
all electrics correctly connected ( check under intake as ususal )
Ecu , well if you had a 172, them its the same basic unit as the 173/380/382 etc etc so as long as it has a 325 chip inside should run ok
can you get the engine to run OK if you hold the revs up ? possibly may be as simple as the ECU has yet to kick back into life, they all idle badly for a few days post battery disconnection.
HTH
mark320i
Post Mon Aug 14, 2006 7:15 pm
the ecu hasnt had the 2.5 chip in yet? could that be the problem?
kam-325i
Post Mon Aug 14, 2006 7:19 pm
mark320i wrote:the ecu hasnt had the 2.5 chip in yet? could that be the problem?
Yes......the ECU still thinks its trying to run a M20B20.
mark320i
Post Mon Aug 14, 2006 7:21 pm
will a zone chip solve this? is there that much difference between the engines then?
seems to good to be true just changing taht over and it running fine?
kam-325i
Post Mon Aug 14, 2006 7:24 pm
there are some big differneces between the 2.0 & 2.5.
Some of the 2.0 engines dont have an ICV, but a vacum thingy to contro idle. the 2.5 Should have the ICV but the 2.0 chip cant control it, hence no idle.
mark320i
Post Mon Aug 14, 2006 7:27 pm
nice 1 kam! il let you know how i get on, cheers mate.
