eko
- Old timer
Post
Thu Aug 10, 2006 1:06 am
can i run a second amp to my front speakers?
Ill explain.
My Alpine head unit only has one set of outputs which are feeding the amp and sub in the boot.
I also have an Alpine amp which id like to run my Infinity components in the front,any way i can run this second one?
cliffybabe
- Powered by Nelly
Post
Thu Aug 10, 2006 1:11 am
Yep RCA splitters is what u need mate, Halfrauds, motorworld or maplins do them, This will allow u to run both amp's with the one output
cliffybabe
- Powered by Nelly
Post
Thu Aug 10, 2006 1:12 am
U will need another wirinf kit though for power etc, U can piggy back the remote, Id use the splitters int he boot were the othe ramp is so u dont have to run loads of cables except for the speaker wire to the boot and the battery cable for the new amp
eko
- Old timer
Post
Thu Aug 10, 2006 1:14 am
excellent,ill go check out `splitter`!
cliffybabe
- Powered by Nelly
Post
Thu Aug 10, 2006 1:19 am
eko wrote:excellent,ill go check out `splitter`!
ur welcome fella if u struggle i can find the details on maplins as i got a set there about 4 months back for a install in a mates motor
eko
- Old timer
Post
Thu Aug 10, 2006 1:28 am
any idea on price?
cliffybabe
- Powered by Nelly
Post
Thu Aug 10, 2006 1:34 am
I think they were 10 or 15 max mate
miniblob
Post
Thu Aug 10, 2006 10:02 am
I never like the idea of splitters, 'cos they halve the signal power/level - but they do have their place and are needed for some systems!!
You may find that your current amp has an output so you can 'daisy chain' another amp from that, which could be a better route!!
Just thought i'd give you another option!
cliffybabe
- Powered by Nelly
Post
Thu Aug 10, 2006 11:06 am
Totaly forgot about that option on some amp's good thinking Rob
miniblob
Post
Thu Aug 10, 2006 11:40 am
Also just thought....... If you do ever need to add a splitter in, it's worth putting a line driver on there to boost the signal before you split it!! Most h/u's give quite a low output and drivers are worthwhile anyway, but if you split it, your obviousely halving the output from your source unit!
You might even be lucky and find some kind of line driver with two outputs (only and idea though, never actually seen one!!)!!!
dark_sounds
Post
Thu Aug 10, 2006 11:47 am
you have pm dude,,, only just read this after sending. llol.
miniblob
Post
Thu Aug 10, 2006 12:18 pm
Didn't get pm - presume it was for cliffybabe??
eko
- Old timer
Post
Thu Aug 10, 2006 12:21 pm
miniblob wrote:Didn't get pm - presume it was for cliffybabe??
Think it was for me mate
dark_sounds
cliffybabe
- Powered by Nelly
Post
Thu Aug 10, 2006 12:30 pm
dark_sounds wrote:for Eko mate
No body loves me
placey
Post
Thu Aug 10, 2006 9:59 pm
most parametric equalisers also double as line drivers. some are installable in the dash. boss audio ones go on ebay for £38, that's about the cheapest new i've seen. dedicated line drivers are usually more expensive for some reason. there are quite a few line drivers with multiple outputs for a single input - required for many-amp setups.
hth - paul
i saw a doctor and she gave me some pills....
miniblob
Post
Fri Aug 11, 2006 10:29 am
That's a good point placey!! Just remembered my kenwood digital eq - goes in a normal single din slot - that takes one input and put's out 3 at (supposedly) 4V!!!!!!!!!
Had that mounted in front of the ashtray (bottom of centre console) in my 320!!! Now where did i put that!!
http://cgi.ebay.co.uk/kenwood-graphic-e ... dZViewItem
That's the one!! (that's no mine on the bay though - no affiliation, blah blah!)
