Delrin and aluminium bushes
Yaninnya
Post Wed Aug 09, 2006 10:25 pm
In the past I have contact only with polyurethane and nylon bushes. How hard are delrin bushes in comparsion with nylon bushes? And how harsher is ride with them?
Also how harsh is ride with aluminium diff mount and rear subframe bushes?
Cheers,
Jan
Taffy
Post Sat Aug 12, 2006 7:58 am
Yes they're stiffer but they stop the deflection better so suspension geometry stays in the position you want it to for longer and for want of a better explanation accept more weight before deflecting, a definite upgrade for diffs and suspension bushes if you are on track
please contact admin with regard to sig
Yaninnya
Post Sat Aug 12, 2006 12:40 pm
Taffy wrote:Yes they're stiffer
They are stiffer than nylon? Did I understand right? And how harsh is ride with aluminium rear beam and diff mountings?
Jan
dibdab
Post Sat Aug 12, 2006 1:40 pm
Aluminium bushes cause a hard ride, not recommended for road use but fantastic for track use.
Taffy
Post Sun Aug 13, 2006 7:15 pm
Yes they make the ride hard, not ideal for a road car but as mentioned superb on track
Yaninnya
Post Fri Aug 18, 2006 11:05 pm
Taffy wrote:Yes they make the ride hard, not ideal for a road car but as mentioned superb on track
Hard? You mean vibrations and noise from diff are quite noticeable?
Cheers,
Jan
Gleb
Post Sat Aug 19, 2006 3:06 am
Depending on your setup, they may be too hard even for the track, I have used E30 M3 ones
And ix for engine mounts, works great for me.
