Z3 diff
Martin347
Post Tue Aug 08, 2006 10:27 am
I know that a z3 rear beam fits an e30, so does the diff?? And if so what ratios do they come in and are they LSD's???
jaistanley
Post Tue Aug 08, 2006 2:57 pm
The rear beam doesn't fit but the wishbones and diff will fit your E30 subframe. ZM's needing different drive flanges if keeping the STD E30 diff as they have larger 5 series type flanges/driveshafts.
Gives you 5 stud with an E36 offset.
Z3's come with LSD's if specced, the M's having 3.15/3.25 plate type diffs and LSD specced everything else having Torsen type (early may not have these)
I think the ratios are of use to those using E36 1:1 5th gearboxes as they are rather low ratio (3.45, 3.64, 3.15 and 3.25 depending on model I beleive)
Don't take any of the above as gospel... I'm still looking into it.
Jai
Martin347
Post Tue Aug 08, 2006 3:19 pm
Thanks for the info, this means its no use for me as i'm looking for a higher ratio diff (4.3-4.5:1). Thanks, Martin.
M3Compact
Post Tue Aug 08, 2006 3:34 pm
I've got a spare 4.1:1 if it's any good to you?
Chris-W
Post Tue Aug 08, 2006 3:45 pm
Rear beam does fit, but there's not a lot of point unless yours is bent as they're virtually identical.
jaistanley
Post Tue Aug 08, 2006 5:24 pm
OK... I've been told the MCoupé/ZMRoadster one I had wouldn't fit by the order of 10-12mm or something (in the spacing of the bush centres). Assumed they are all the same.
Jai
