head refitment
Martin323i
Post Sat Aug 05, 2006 8:57 am
Can the headbolts and cambelt be reused when refitting the head?
My mechanic assures me this would be fine, but I remember reading somewhere that these would need to be new.
I had the cambelt replaced not so long ago though.
Thanks in advance :)
Chris-W
Post Sat Aug 05, 2006 9:00 am
I always replace the headbolts, even if they're not stretch bolts. If yours have torx heads they definitely need to be replaced.
For the cost, you're as well to change the belt as well whilst you have the opportunity.
Templ8e30
Post Sat Aug 05, 2006 8:09 pm
Headbolts MUST be renewed, cambelt is advisable.
A cambelt and bolts only cost £25 to £30, imagine not renewing them and having them fail ! you'd have to shell out to have the whole job done again with new bits anyway.
Change them :D
Cheers,
Iain T
2007 Mazda 6 2.0 estate
gooner1
Out humping Reindeer
Post Sat Aug 05, 2006 8:13 pm
Martin id add the water pump to that list mate.Unless you done it on your recent cambelt change.
Post Sat Aug 05, 2006 10:16 pm
You'd probably get away with re using both of them once, but as Templ8e30 says, they're not that expensive - but the cost of them failing is.
