I need new wheels and have a good offer on some BMW Mini wheels.
I know both cars a 4 stud.
Anyone help please??
James
Do the wheels off a new BMW Mini fit an E30 3 series????
i think the studs match
but the offset is a fair bit different i think
so you would need spacers to fit them
but i could be wrong?
www.oldskoolfantasy.co.uk
The bolt pattern is 4x100mm.
The centerbore is 56.1mm.
The offset (ET) can range from 35mm to 52mm depending on the wheel size.
this means that, as far as i know, everything is ok, but the offset is too high. you will need pro-spacers, of around 30mm...this isnt the best thing to do, i would say 10-20mm spacers at most really
