325i 3 peice exhaust question - with pics
max_crox
Post Mon Jul 31, 2006 9:49 pm
Ive just purchased a brand new 3 peice exhaust. The rear and centre box I got from GSF and the front down pipe came from KMS in Birmingham.
Mid Section
Front Section
Joined
Is this how they are suppose to join together? I understand the bottom pipe but how are the top pipes secured together as the front section pipe is actually inside the mid section pipe? have I got the right down pipe?
Mark
A1BMW325iSport
Post Mon Jul 31, 2006 10:14 pm
thats the wrong downpipes mate they should have flange on both pipes like the centre section winkeye
Martinaston
Post Mon Jul 31, 2006 10:41 pm
Pretty sure thats the same as mine, and mines still the original.
One seal goes between the flanges and the other one goes over the end of the straight pipe, you have to have the sliding fit otherwise the join will sag because all the weight is resting on the bolts.
max_crox
Post Mon Jul 31, 2006 10:45 pm
thats the wrong downpipes mate they should have flange on both pipes like the centre section Wink
Bugger I was hoping you wouldn't say that.
Any Idea what I have then they said it was for a 325.
The thing is if there was a flange on the end of the pipe it wouldn't mate correctly. As it is it fits snugly inside the other pipe and mates perfectly apart from not knowing how the other pipe is secured
Gap issues
How may different types of down pipes are there as I doubt there would have been that many as you would never know which one you would need!
It's going in for its MOT on Saturday so I need to get the parts together before then. GSF only have a down pipe listed for a 320i so I was slightly reluctant to get that one because they didn't know if it would fit. Hence why I went to KMS as they had this listed for the 325i
Mark
max_crox
Post Mon Jul 31, 2006 10:47 pm
Martinaston wrote:Pretty sure thats the same as mine, and mines still the original.
Ahh makes me feel better. That does actually make sense. how is the slifing one secured in then?
Martinaston
Post Mon Jul 31, 2006 10:57 pm
You either need a fitting kit :roll: or just use the old clamps and seals (olives).
Good luck getting the old olive off and it may be worth getting new nuts and bolts, depending on the condition of your old ones.
There is NO nucleus.
max_crox
Post Mon Jul 31, 2006 11:16 pm
I have a totally new fitting kit from GSF so I think everything should be in there then. This 3 peice system is replacing my 2 peice so I dont think ill be able to use any of the old parts. Plus they are mega rusty! :)
Post Tue Aug 01, 2006 1:33 am
that all looks fine to me. I wouldn't re use the old crushable ring gaskets off the old system. new ones are pence
Thats how they fit together
max_crox
Post Tue Aug 01, 2006 8:11 am
Cheers Guys.
I got sligtly worried! :)
Mark
GDBN
Post Tue Aug 01, 2006 5:11 pm
I asked the same question a week or two back. There is a fibre ring (on the inside) that slides over the down pipe with the flat edge. This will push up the pipe far enough so the other 2 meet. The 2 with the "lips" on the edges then join with a steel ring between them.
G
fazgti
Post Tue Aug 01, 2006 5:19 pm
alright max how much did you pay for the sections from gsf cheers faz
TouringMatt
Post Tue Aug 01, 2006 5:52 pm
Hi Mark, - noticed in the background you got the rims sprayed, lookin good winkeye
Matt
max_crox
Post Tue Aug 01, 2006 9:43 pm
fazgti wrote:alright max how much did you pay for the sections from gsf cheers faz
Hey Faz,
Well for the back and centre box, fitting kit and joining rings came to £169. Thats with the high quality back box. The down pipe was £41 from KMS. so i think (hope) i got a good deal :)
max_crox
Post Tue Aug 01, 2006 9:46 pm
TouringMatt wrote:Hi Mark, - noticed in the background you got the rims sprayed, lookin good winkeye
Matt
Hey Matt. Cheers, I been really lazy with getting them done.
How have yours turned out? Acquired any more?? :)
Mark
TouringMatt
Post Wed Aug 02, 2006 2:55 pm
Mark
Slow progress, not really touched them since i last saw you :oops:
Thinking of getting them sandblasted, real pain in the ass trying to get the old paint off, just need to find somewhere :roll:
Matt
fazgti
Post Wed Aug 02, 2006 3:06 pm
na thats cheap kwic shit wanted £122 for the middle box and £118 for the rear box=£240 so i might be paying gsf a visit but only for a middle box
