wheres a constant 12v inside the car?
tregzybmw
Post Sun Jul 30, 2006 7:58 pm
the 12v feed for my central locking is buggered. but when i connect it up to a wire from the positive on the battery, its works like a dream.
i now need to do it for real, so, where can i tap into a 12v constant supply from inside my car??
smithy318i
Post Sun Jul 30, 2006 8:02 pm
the thick red/black wires right next to the c/l relay.
E30Mark
Post Sun Jul 30, 2006 8:26 pm
The black / red wire (12V permenant feed) circumnavigates the car before it gets to the C/L relay...
It runs from behind the glove-box, down the side of the passenger sill, under the rear seat, then back down the length of the drivers sill to the C/L relay. Cut the black / red wire near the glove-box and run a wire under the dash straight to the C/L relay...
Also check the condition of the multiway connector in the the A post, the black / red wire loops in & out of the door for some unknown reason... (Brianmooooooore is the man!)
PM for details
tregzybmw
Post Sun Jul 30, 2006 11:14 pm
mine is a one off problem.....
it will take to long to explain, but basically, the red and black wire thing doesnt work at all!!
cheers for the details guys :cool:
stevetigger
Post Mon Jul 31, 2006 7:41 pm
ciggy lighter!
alane
Post Mon Jul 31, 2006 8:07 pm
i would be tempted to find out why the power to the c/l relay is fecked and try and resolve it rather than bodging it up .
its failed for a reason .maybe blown fuse, earthing on something or the wire has perished ?
tregzybmw
Post Mon Jul 31, 2006 11:25 pm
alane wrote:i would be tempted to find out why the power to the c/l relay is fecked and try and resolve it rather than bodging it up .
deffo agree with that, am fitting a toad ai606 in a bit, will check then, just need a quick fix, as no central locking is rather annoying!
