Hi I need a new cluster for my 1992 325i. Does anyone know if the older cluster will fit. I have the newer type of battery in my si board
Cheers Andrew
Instrument cluster
All E30 clusters are a direct replacement, except for M3 and very early ones with the different kind of coding plug.
SI boards with different batteries are interchangeable, but the lithium type are more reliable.
Use the coding plug from your original cluster.
cliffybabe
- Powered by Nelly
Were abouts r ya mate, i have a couple heretomski wrote:Hi I need a new cluster for my 1992 325i. Does anyone know if the older cluster will fit. I have the newer type of battery in my si board
Cheers Andrew
tomski
Cardiff mate, how much do you want for one delivered? Mines on 100,000 got one near to that?
Thanks Andrew
Thanks Andrew
