Removing Door Cards
dandlesbne
Would anyone have an directions/tips on how to best remove the front & rear door cards from a 2 door. Thanks in advance.
appletree
first ubndo all the screw you can cthen you should just be able to pop the rest of the door card off because it gao those little chritmas tree shaped clips.
also get a small flat bade crew driver and prise out the eletric mirror switch and there s a screw hiddinh behine this! iirc you also have to unplug the switch
hope that helps
hope that helps
Chris-W
Don't forget the door pin!
DaveD
- E30Zone Wiki Specialist
first take out the mirror switch and take the screw out if ther then take out the door handle surround then undo the two screws from the arm rest. carefuly , from the bottom pull away the door carrd till it is just hung on fom the top then pull up and off
when replacing the trick is to get the screws in from the switch first and find the sockets BEFORE you tighten them up
Geeman
Yeah, remember the door pin... it just unscrews. You won't be able to get the door-card off without doing this.
Also, if you have manual windows, you must take off the handle too!
bmwe30mtech
MThe rear quarter panels have metal 'prongs' along the tops of them. They must be unclipped at the front near the door opening, then lifted upwards and out. try using a pollyfiller spatualr for prising them off, worked for me!
